Ga door naar hoofdinhoud
Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement
Wat je nodig hebt
  1. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, J1 Screws on Throttle: stap 1, afbeelding 1 van 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: stap 2, afbeelding 1 van 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: stap 2, afbeelding 2 van 2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: stap 3, afbeelding 1 van 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: stap 3, afbeelding 2 van 2
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
  4. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 4, afbeelding 1 van 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 4, afbeelding 2 van 2
    • Pull the panel that is covering the R2 button away from the throttle.
  5. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 5, afbeelding 1 van 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 5, afbeelding 2 van 2
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
  6. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 6, afbeelding 1 van 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
  7. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 7, afbeelding 1 van 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: stap 7, afbeelding 2 van 2
    • Carefully push the L2 button from the outside of the panel.
Conclusie
Crystal Nguyen
624 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Lid van CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Leden
13 handleidingen geschreven
Één opmerking
Hello, m R2 button is broken. Do you know where i can print a new one ?
louis_tiquet - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,335
