Ga door naar hoofdinhoud
ThinkPad Yoga 12 Battery Replacement
Wat je nodig hebt
  1. ThinkPad Yoga 12 Battery Replacement, Screws: stap 1, afbeelding 1 van 3 ThinkPad Yoga 12 Battery Replacement, Screws: stap 1, afbeelding 2 van 3 ThinkPad Yoga 12 Battery Replacement, Screws: stap 1, afbeelding 3 van 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Battery Replacement, Prying: stap 2, afbeelding 1 van 2 ThinkPad Yoga 12 Battery Replacement, Prying: stap 2, afbeelding 2 van 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: stap 3, afbeelding 1 van 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: stap 4, afbeelding 1 van 2 ThinkPad Yoga 12 Battery Replacement, Removing the screw: stap 4, afbeelding 2 van 2
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: stap 5, afbeelding 1 van 2 ThinkPad Yoga 12 Battery Replacement, Lift: stap 5, afbeelding 2 van 2
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: stap 6, afbeelding 1 van 3 ThinkPad Yoga 12 Battery Replacement, Connecter: stap 6, afbeelding 2 van 3 ThinkPad Yoga 12 Battery Replacement, Connecter: stap 6, afbeelding 3 van 3
    • Carefully pull the connector out from underneath the logic board to remove the battery.
Conclusie
9 andere personen hebben deze handleiding voltooid.
[deleted]
1.324 Reputatie
3 handleidingen geschreven
Één opmerking
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 32
Altijd: 6,606
