Ga door naar hoofdinhoud
ThinkPad X1 Carbon Fingerprint Reader Replacement
Wat je nodig hebt
  1. ThinkPad X1 Carbon Fingerprint Reader Replacement, Fingerprint Reader: stap 1, afbeelding 1 van 1
    • Unscrew the seven screws located on the back of the device.
  2. ThinkPad X1 Carbon Fingerprint Reader Replacement: stap 2, afbeelding 1 van 1
    • Slide the plastic opening tool along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Fingerprint Reader Replacement: stap 3, afbeelding 1 van 1
    • Flip the device over and open it to lift the keyboard tray from the body of the device.
  4. ThinkPad X1 Carbon Fingerprint Reader Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to gently release the ribbon cable attached to the keyboard.
    • You may now place the device off to the side. The rest of the repair takes place on the keyboard tray.
  5. ThinkPad X1 Carbon Fingerprint Reader Replacement: stap 5, afbeelding 1 van 1
    • Locate the Fingerprint Reader and metal frame on the left side of the keyboard tray.
  6. ThinkPad X1 Carbon Fingerprint Reader Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the two silver screws to remove the metal frame.
  7. ThinkPad X1 Carbon Fingerprint Reader Replacement: stap 7, afbeelding 1 van 1
    • Remove the ribbon cable connected to the board.
    • Remove and Replace the Fingerprint Reader board and metal frame.
    • This connection does not have a lock, please pull the ribbon away from the board. Do not attempt to lift the connection.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 52
Altijd: 2,972
