Inleiding
This tutorial will help you replace the battery of your Pave Parisien
Pull the speaker out a bit to access the connectors
With light gentle movements, pull and disconnect the two cables from the connections
Pull the speaker completely out of the recessed compartment
Gently pull the board behind the speaker out and place on a flat surface
Disconnect the battery connector from the board
Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure
Push the battery from the rear towards the opening where the wires are
The battery is out and now it can be changed
Pass the connector through the space that is indicated for it
The texture of this surface is different from the other three faces. Orient yourself to how it fits correctly.
First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
