Ga door naar hoofdinhoud
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
Wat je nodig hebt
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: stap 1, afbeelding 1 van 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 2, afbeelding 1 van 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 3, afbeelding 1 van 2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 3, afbeelding 2 van 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: stap 4, afbeelding 1 van 1
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 5, afbeelding 1 van 1
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 6, afbeelding 1 van 2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 6, afbeelding 2 van 2
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: stap 7, afbeelding 1 van 1
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
Conclusie
Jacob
601 Reputatie
6 handleidingen geschreven
Cal Poly, Team 8-4, Banghart Winter 2017 Lid van Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 666
