Inleiding
In this guide we will show you how to replace the 5 way toggle switch on a Rock Band Beatles Hofner Bass.
Wat je nodig hebt
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
With a J1 Phillips screwdriver, remove the six 5mm on the cover.
Remove the cover.
