Inleiding
Through this guide you will learn how to replace the strummer in a Rock Band Beatles Hofner Bass.
Wat je nodig hebt
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
Use a J1 Phillips head screwdriver to remove the four 10mm screws at the corners of the black casing.
