Ga door naar hoofdinhoud
The Beatles Rock Band Hofner Bass Back Plate Replacement
Wat je nodig hebt
  1. The Beatles Rock Band Hofner Bass Back Plate Replacement, Back Plate: stap 1, afbeelding 1 van 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Back Plate Replacement: stap 2, afbeelding 1 van 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Back Plate Replacement: stap 3, afbeelding 1 van 2 The Beatles Rock Band Hofner Bass Back Plate Replacement: stap 3, afbeelding 2 van 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
Conclusie
Jacob
601 Reputatie
6 handleidingen geschreven
Cal Poly, Team 8-4, Banghart Winter 2017 Lid van Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 20
Altijd: 838
