Inleiding
The keyboard mat is what makes contacts with the motherboard. If the keys are not working very well then the mat may need replacing.
Wat je nodig hebt
Remove the battery cover.
Remove the AAA batteries from the calculator.
Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
Remove the eight (8) 5mm Philips #00 screws on the motherboard.
Één andere persoon heeft deze handleiding voltooid.
