Inleiding
If one or a number of your keys are broken or cracked, causing malfunctions in operation or dangerous sharp edges, use this guide to safely replace them.
Wat je nodig hebt
Remove the battery cover.
Remove the AAA batteries from the calculator.
Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
Remove the eight (8) 5mm Philips #00 screws on the motherboard.
