Ga door naar hoofdinhoud
Inleiding
This guide demonstrates and describes proper removal and replacement of the back casing. It is needed to access other parts for repair or replacement.
  1. Locate battery cover on the back of the case.
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Remove battery cover.
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing. Unscrew four 7.15 mm screws from back casing. Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
Conclusie
Calvin
201 Reputatie
2 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 149
