Ga door naar hoofdinhoud
Texas Instruments TI BA II PLUS Battery Replacement
Wat je nodig hebt
  1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Texas Instruments TI BA II PLUS  Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Switch off the calculator by pressing the button at the top right corner.
  2. Texas Instruments TI BA II PLUS  Battery Replacement: stap 2, afbeelding 1 van 1
    • Turn over the calculator so the backside of the calculator is facing upwards.
    • Remove the four 2mm Phillips #00 screws from the bottom cover.
  3. Texas Instruments TI BA II PLUS  Battery Replacement: stap 3, afbeelding 1 van 1
    • Open a small gap at the bottom of the calculator, using a spudger or your fingers.
    • Move your thumb from the bottom edge to the top.
    • Be gentle when separating the cases to avoid breaking the clips.
  4. Texas Instruments TI BA II PLUS  Battery Replacement: stap 4, afbeelding 1 van 3 Texas Instruments TI BA II PLUS  Battery Replacement: stap 4, afbeelding 2 van 3 Texas Instruments TI BA II PLUS  Battery Replacement: stap 4, afbeelding 3 van 3
    • Use a spudger to remove the battery from the cage at the bottom of the motherboard.
  5. Texas Instruments TI BA II PLUS  Battery Replacement: stap 5, afbeelding 1 van 1
    • Replace the battery with the new CR2032 Lithium Battery in the battery cage.
  6. Texas Instruments TI BA II PLUS  Battery Replacement: stap 6, afbeelding 1 van 2 Texas Instruments TI BA II PLUS  Battery Replacement: stap 6, afbeelding 2 van 2
    • Reattach the calculator cases, beginning from the top edge.
    • Use the Phillips #00 screwdriver to replace the 2.00 mm screws.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Peipei Yu
214 Reputatie
1 Handleiding geschreven
Één opmerking
It's amazing that this calculator can break. I am an accountant student in college and despite modern technologies and the rather powerful functionality of modern smartphones, I like to use just such a calculator for financial calculations.
AlGorFun - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 179
Afgelopen 30 dagen: 704
Altijd: 21,859
