Inleiding
A detailed guide on how to use a continuity tester to check for adequate electrical connection on a power cord.
Wat je nodig hebt
Set the multimeter to continuity test mode.
Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
Repeat the above directions in step 2 for the other outlet and prong of the power cord.
Est-il possible de brancher sur une autre prise alimentée pour savoir si cordon et appareil sont non défectueux ??? Sans danger; faire sauter fusibles etc. Merci.
Could that be the problem why I am not getting but just a tad of electricity to my outlets I'm not getting enough power to run anything?
Test for a potential short circuit by touching each prong on the AC side of the power cord.
If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
is there a guide like this very useful one but to test the surface power cords ?
146 andere personen hebben deze handleiding voltooid.
13 opmerkingen
Thank you very much.
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Brilliant love it
Superb...thanks a lot!!
Now I know how to test a power cord.
How do I test a switch?
Can you do a continuity test on the Xbox One Original CONSOLE ?
