Ga door naar hoofdinhoud
Tesla Model S Key Fob Battery Replacement
Wat je nodig hebt
  1. Tesla Model S Key Fob Battery Replacement, Key Fob Battery: stap 1, afbeelding 1 van 3 Tesla Model S Key Fob Battery Replacement, Key Fob Battery: stap 1, afbeelding 2 van 3 Tesla Model S Key Fob Battery Replacement, Key Fob Battery: stap 1, afbeelding 3 van 3
    • Remove the protective case from the key fob.
    • This step is optional; not everyone has a protective case.
  2. Tesla Model S Key Fob Battery Replacement: stap 2, afbeelding 1 van 3 Tesla Model S Key Fob Battery Replacement: stap 2, afbeelding 2 van 3 Tesla Model S Key Fob Battery Replacement: stap 2, afbeelding 3 van 3
    • Insert the flat end of a spudger into the notch, and gently pry the key fob open along the seam.
    • Separate the cover from the key fob.
  3. Tesla Model S Key Fob Battery Replacement: stap 3, afbeelding 1 van 3 Tesla Model S Key Fob Battery Replacement: stap 3, afbeelding 2 van 3 Tesla Model S Key Fob Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert the flat end of a spudger into the entry point at the top of the key fob.
    • Lightly push the spudger under the battery.
    • Remove the battery from the key fob.
  4. Tesla Model S Key Fob Battery Replacement: stap 4, afbeelding 1 van 3 Tesla Model S Key Fob Battery Replacement: stap 4, afbeelding 2 van 3 Tesla Model S Key Fob Battery Replacement: stap 4, afbeelding 3 van 3
    • With your fingers, insert a new CR2032 battery into the opening.
    • Ensure correct placement of the battery by having the writing facing up toward you and the blank side with a number facing down inside the battery opening.
    • Push the battery with your thumb to lock it into place.
  5. Tesla Model S Key Fob Battery Replacement: stap 5, afbeelding 1 van 3 Tesla Model S Key Fob Battery Replacement: stap 5, afbeelding 2 van 3 Tesla Model S Key Fob Battery Replacement: stap 5, afbeelding 3 van 3
    • To close the key fob, enter the wider side of the cover into the opening in the middle of the key fob.
    • You should see the end of the cover a little popped out.
    • With your thumb and pointer finger push together the cover and the key fob to allow for the key fob to be securely closed.
  6. Tesla Model S Key Fob Battery Replacement: stap 6, afbeelding 1 van 3 Tesla Model S Key Fob Battery Replacement: stap 6, afbeelding 2 van 3 Tesla Model S Key Fob Battery Replacement: stap 6, afbeelding 3 van 3
    • This step is optional (not everyone has a case).
    • Place the key fob into the opening of the case.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Stefanie Ayala
196 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 4-3, Briggs Spring 2022 Lid van CSU Los Angeles, Team 4-3, Briggs Spring 2022
CSULA-BRIGGS-S22S4G3
1 Lid
2 handleidingen geschreven
2Gids Commentaar
Really, that tip was helpful, the last time i my model s tesla key fob's battery was dead, I order another on amazon, and some tips online here on tesla key fob programming. At first, I was a little bit skeptical given that I have not done such a thing before on my tesla. However, the process was really simple and the guide on the site was helpful.
Ayo Idowu - Antwoord Deel
hello thanks for WRONG INFORMATION on 2022 s key fob it does not take 2032 battery
masterchief - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 125
Altijd: 6,917
