Ga door naar hoofdinhoud
Tennis Racquet Grip Tape Replacement
Wat je nodig hebt
  1. Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: stap 1, afbeelding 1 van 2 Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: stap 1, afbeelding 2 van 2
    • Pull the rubber collar towards the tennis racquet head off the handle.
  2. Tennis Racquet Grip Tape Replacement: stap 2, afbeelding 1 van 1
    • Unwrap the tape on the tennis racquet handle top.
  3. Tennis Racquet Grip Tape Replacement: stap 3, afbeelding 1 van 3 Tennis Racquet Grip Tape Replacement: stap 3, afbeelding 2 van 3 Tennis Racquet Grip Tape Replacement: stap 3, afbeelding 3 van 3
    • Remove the old grip.
    • Some older tennis racquets may have a few staples holding the grip to the buttcap. Use the staple remover to take them out.
  4. Tennis Racquet Grip Tape Replacement: stap 4, afbeelding 1 van 1
    • Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
  5. Tennis Racquet Grip Tape Replacement: stap 5, afbeelding 1 van 2 Tennis Racquet Grip Tape Replacement: stap 5, afbeelding 2 van 2
    • Face the racquet so the buttcap is towards you.
    • If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
    • If you are right-handed, wrap the tape towards the left
    • Wrap the grip flush with the buttcap base.
  6. Tennis Racquet Grip Tape Replacement: stap 6, afbeelding 1 van 2 Tennis Racquet Grip Tape Replacement: stap 6, afbeelding 2 van 2
    • Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
    • Stop wrapping just before you finish wrapping the handle.
    • The handle is the off color or unpainted portion below the tennis racquet head.
  7. Tennis Racquet Grip Tape Replacement: stap 7, afbeelding 1 van 2 Tennis Racquet Grip Tape Replacement: stap 7, afbeelding 2 van 2
    • Wrap the handle top with the backing on.
    • Mark a horizontal line parallel to the buttcap around the grip.
  8. Tennis Racquet Grip Tape Replacement: stap 8, afbeelding 1 van 1
    • Cut along the marked line using either scissors or a knife.
    • Cutting with scissors is significantly easier, however if you do not have scissors that can cut the grip, a knife will work.
  9. Tennis Racquet Grip Tape Replacement: stap 9, afbeelding 1 van 1
    • Remove the backing and finish wrapping the replacement grip.
  10. Tennis Racquet Grip Tape Replacement: stap 10, afbeelding 1 van 1
    • Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
  11. Tennis Racquet Grip Tape Replacement: stap 11, afbeelding 1 van 2 Tennis Racquet Grip Tape Replacement: stap 11, afbeelding 2 van 2
    • Complete your fix by pulling the rubber collar back to its original location.
    • If you do not wish to add an overgrip, skip step 12.
  12. Tennis Racquet Grip Tape Replacement: stap 12, afbeelding 1 van 1
    • Pull the collar up off the handle.
    • Repeat steps 4 - 11 to apply the overgrip.
Conclusie
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
6 andere personen hebben deze handleiding voltooid.
Aisleen Santos
196 Reputatie
1 Handleiding geschreven
UC Davis, Team S3-G1, Coad Spring 2017 Lid van UC Davis, Team S3-G1, Coad Spring 2017
UCD-COAD-S17S3G1
3 Leden
2 handleidingen geschreven
4 opmerkingen
Thank you I’ve found particularly useful the, then obvious when you think about it, comment that left handed setup is different to the right handed one!
Sam Curti - Antwoord
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
JACKSON RYAN - Antwoord
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
Tennis Unit - Antwoord
I use this tennis guide, it’s quite worthy.
Rondaromero - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 105
Altijd: 18,341
