Ga door naar hoofdinhoud
Tengda S5 Plus Rear Camera Replacement
Wat je nodig hebt
  1. Tengda S5 Plus Rear Camera Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Rear Camera Replacement: stap 2, afbeelding 1 van 2 Tengda S5 Plus Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Rear Camera Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Rear Camera Replacement, Rear Camera: stap 4, afbeelding 1 van 1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Rear Camera Replacement: stap 5, afbeelding 1 van 2 Tengda S5 Plus Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Place the phone facing screen down.
    • Using the plastic prying tool, gently disconnect the black connector cable.
    • The connector cable should easy snap out with little force.
  7. Tengda S5 Plus Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Using the plastic prying tool, pry the camera from the tape holding it in place.
    • Be careful not to rip the tape.
Conclusie
Jholmesford
188 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-9, Amido Spring 2015 Lid van Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 276
