Ga door naar hoofdinhoud
Tengda S5 Plus Home Button Replacement
Wat je nodig hebt
  1. Tengda S5 Plus Home Button Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Home Button Replacement: stap 2, afbeelding 1 van 2 Tengda S5 Plus Home Button Replacement: stap 2, afbeelding 2 van 2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Home Button Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Home Button Replacement, Home Button: stap 4, afbeelding 1 van 1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Home Button Replacement: stap 5, afbeelding 1 van 2 Tengda S5 Plus Home Button Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, create a small gap between the front screen and the metal casing. Slide the plastic opening tool around the phone counterclockwise to make this gap around the entire phone.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Home Button Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Lay your device with the screen faced down.
    • Using tweezers, lift the two pieces of yellow tape holding the wire in place.
  7. Tengda S5 Plus Home Button Replacement: stap 7, afbeelding 1 van 2 Tengda S5 Plus Home Button Replacement: stap 7, afbeelding 2 van 2
    • Using the tweezers again, grasp the wire and free it from the crevice.
    • This will provide slack for you to work with the lower motherboard.
  8. Tengda S5 Plus Home Button Replacement: stap 8, afbeelding 1 van 3 Tengda S5 Plus Home Button Replacement: stap 8, afbeelding 2 van 3 Tengda S5 Plus Home Button Replacement: stap 8, afbeelding 3 van 3
    • Remove the silver tape that holds the lower motherboard to the front panel of the phone.
  9. Tengda S5 Plus Home Button Replacement: stap 9, afbeelding 1 van 2 Tengda S5 Plus Home Button Replacement: stap 9, afbeelding 2 van 2
    • Using your fingers, or the Metal Spudger, disconnect the black cable connector.
    • The cable connector should easy snap out with little force.
  10. Tengda S5 Plus Home Button Replacement: stap 10, afbeelding 1 van 3 Tengda S5 Plus Home Button Replacement: stap 10, afbeelding 2 van 3 Tengda S5 Plus Home Button Replacement: stap 10, afbeelding 3 van 3
    • Using your fingers, slide the lower motherboard towards you.
    • The lower motherboard will still be attached to the front panel by a red and blue cable on the left side and a long silver wire on the right side, but you should now have visibility of the home button.
  11. Tengda S5 Plus Home Button Replacement: stap 11, afbeelding 1 van 2 Tengda S5 Plus Home Button Replacement: stap 11, afbeelding 2 van 2
    • Clean away any dirt from the back side of the lower motherboard, underneath the charging port.
    • Using tweezers, grasp and remove the home button.
Conclusie
Kenny Levy
125 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-9, Amido Spring 2015 Lid van Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 498
