Ga door naar hoofdinhoud
Tektro Aires Disc Brakes Brake Pad Replacement
Wat je nodig hebt
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: stap 1, afbeelding 1 van 1
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: stap 2, afbeelding 1 van 2 Tektro Aires Disc Brakes Brake Pad Replacement: stap 2, afbeelding 2 van 2
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: stap 3, afbeelding 1 van 1
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: stap 4, afbeelding 1 van 1
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: stap 5, afbeelding 1 van 1
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: stap 6, afbeelding 1 van 1
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
Conclusie
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
Randall Eakes
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 152
Altijd: 3,326
