Ga door naar hoofdinhoud
Tefal Actifry Disassembly
Wat je nodig hebt
  1. Tefal Actifry Disassembly, Tefal Actifry Disassembly: stap 1, afbeelding 1 van 3 Tefal Actifry Disassembly, Tefal Actifry Disassembly: stap 1, afbeelding 2 van 3 Tefal Actifry Disassembly, Tefal Actifry Disassembly: stap 1, afbeelding 3 van 3
    • This is the Tefal Actifry as it would sit when being used. You will need to turn it upside down to see the three security screws that need to be removed. I have circled them in red here. The next photo shows a closeup of one of the screws.
  2. Tefal Actifry Disassembly: stap 2, afbeelding 1 van 3 Tefal Actifry Disassembly: stap 2, afbeelding 2 van 3 Tefal Actifry Disassembly: stap 2, afbeelding 3 van 3
    • Next remove the three screws and the little fan cover at top end of the unit. I gently prised it off with a butter knife. This allows the bottom plastic cover of the Actifty to come off, from the fan end first, then it slips over the lid release buttons and off.
  3. Tefal Actifry Disassembly: stap 3, afbeelding 1 van 3 Tefal Actifry Disassembly: stap 3, afbeelding 2 van 3 Tefal Actifry Disassembly: stap 3, afbeelding 3 van 3
    • The motor is now exposed with the bottom cover removed. There are two security screws, the same size as the ones on the outside cover that need removed. There are two wires that need removed from the old motor and inserted into the new motor. The new can be secured in place and tightened with the screws.
  4. Tefal Actifry Disassembly: stap 4, afbeelding 1 van 2 Tefal Actifry Disassembly: stap 4, afbeelding 2 van 2
    • When the wires are inserted snugly into the new motor and all is secure the bottom can be put back on the Actifry. Remember to slip it on in reverse of how you removed it. I had a little trouble getting it over the buttons, but it will with a little manipulation.
  5. Tefal Actifry Disassembly: stap 5, afbeelding 1 van 2 Tefal Actifry Disassembly: stap 5, afbeelding 2 van 2
    • I took my old motor apart to see why it wouldn't work. I discovered a circular magnet in the bottom, underneath the cogs etc. Upon closer inspection I seen it was cracked and a little pull and it came apart. It made it's way to the bin.
Conclusie
34 andere personen hebben deze handleiding voltooid.
Declan Green
1.056 Reputatie
1 Handleiding geschreven
35 opmerkingen
Thank you for the great guide. I'd like to mention a few things I discovered disassembling my actifry while following your instructions:
* the screws on my unit were regular torx - ie not security torx which have the pin in the middle that require bits with a corresponding hollow hole.
* the fan cover is made of very brittle plastic and is easy to break when trying to pry off.
* the fan cover is held by 3 tabs at the 9, 3, and 12'o clock positions. It is easiest to pry from the the tabs at 9 and 3'o clock positions.
ifabri - Antwoord
Thank you!! I am not at all DIY minded. I ordered a part for £12 on amazon, founder a screwdriver in my husband's toolbox, and fixed my actifry in under 5 minutes. Fab guide thank you!
Angharad - Antwoord
Hi I've just fitted a new motor but now not getting hot. Do you think I need to replace element too? Also my friend has an actifry with same problem but can't find a motor for the model AL806240. Any ideas where she can get one. The wires seem to sit differently than mine. Thank you
Jean Hennedy - Antwoord
This is what is happening to mine. I have replaced the motor and now the actifry is not heating… did you find the solution? Thanks
l.z.macintyre -
Thanks, saved time figuring out exactly how to do it - though you need a couple of more pictures in the guide. I had to deform the case a bit in order to clear over the fan otherwise it cannot slip over the fan - people be careful not to stress the fan assembly: you should slide the case without touching the fan.
In my case, the security screws *just* got unscrewed by a not-security screwdriver bit so I just replaced them with normal philips ones on reassembly.
MiKa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 135
Afgelopen 30 dagen: 610
Altijd: 115,308
