Ga door naar hoofdinhoud
Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement
Wat je nodig hebt
  1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: stap 1, afbeelding 1 van 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: stap 1, afbeelding 2 van 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 2, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 2, afbeelding 2 van 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Battery: stap 4, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 5, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Expansion Module: stap 6, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Expansion Module: stap 6, afbeelding 2 van 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Midframe: stap 8, afbeelding 1 van 1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 9, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 9, afbeelding 2 van 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 10, afbeelding 1 van 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 10, afbeelding 2 van 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 10, afbeelding 3 van 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 11, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 11, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Pitch Bend Button: stap 12, afbeelding 1 van 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Pitch Bend Button: stap 12, afbeelding 2 van 2
    • Use a spudger or your finger to push the pitch bend button inwards.
  13. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: stap 13, afbeelding 1 van 1
    • Carefully lift and remove the pitch bend button.
    • The button has two small holes which engage with two pins in the midframe.
    • Make sure the two holes and pins align when reinstalling the new button.
Conclusie
Tobias Isakeit
117.296 Reputatie
188 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.521 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 39
Altijd: 1,669
