Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The display not only gives you useful information, it is also fun to watch the small animations while making sounds. If the display should fail this guide will show you how to replace it.
  1. To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total). The four longer keys from the fingerboard are to be handled from the left side to get them off. The eight smaller keys need to be levered from the bottom up.
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. The scissor mechanism of the eight small keys are obstructing the underlying screws. By using again an opening tool or opening pick these can be snapped off easily.
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  4. Loosen those 12 screws with a Phillips #00 screwdriver. Then just pull off the four rotary knobs and the volume knob. Now it is possible to slightly lift the keyboard and set it back.
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
    Your missing the ribbon decoupling step, unless you skipped it because it’s such a tight squeeze to get back in.
    William “Zoe” FitzGerald - Antwoord
  5. Open the display cable connector by using a plastic opening tool to flip the latch upwards. The display is held in place with a mild adhesive. A spudger helps you to get it free. Now you can unplug the cable and take out the whole display.
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
    • After reassembly you want to perform the three function tests (0, 1 and 2) from the OP-1 special start screen. You can enter this menu by holding the COM key when powering up.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
78.138 Reputatie
150 handleidingen geschreven
iFixit Lid van iFixit
Community
131 Leden
13.426 handleidingen geschreven
It is really helping.
do you know where to get the screen?
thank you.
chefshin - Antwoord
I see that the part # is AMS260CM61 ver 2 by Samsung. However, I have not been able to source it online.
Mike - Antwoord
Hey guys,
Can someone from IFIXIT please let us know where we can buy the screen please.
my screen is cracked and i desperately need to replace it.
Thanks!
Jack - Antwoord
Hi Jack, unfortunately we do not know where to get a replacement screen for the OP-1. You might want to get in contact with the guys from Teenage Engineering directly. Sorry
Tobias Isakeit -
Jack, look for “part number 74-x000045”, there are few of them out there. Cheers.
Peter O -
What about the new rev 2.0 op-1
Can you source those screens ?
Newer push in connection.
Or anyone got the specs or compatible part number ?
Yes, also messaged t.e
Gadget - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 104
Altijd: 8,035
