Ga door naar hoofdinhoud
Teenage Engineering OP-1 Connector Board Replacement
Wat je nodig hebt
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: stap 1, afbeelding 1 van 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: stap 1, afbeelding 2 van 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: stap 1, afbeelding 3 van 3
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: stap 2, afbeelding 1 van 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: stap 2, afbeelding 2 van 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: stap 2, afbeelding 3 van 3
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: stap 3, afbeelding 1 van 2 Teenage Engineering OP-1 Connector Board Replacement: stap 3, afbeelding 2 van 2
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
Conclusie
46 andere personen hebben deze handleiding voltooid.
teenage engineering
1.095 Reputatie
2 handleidingen geschreven
Teenage Engineering Lid van Teenage Engineering
Community
3 Leden
7 handleidingen geschreven
44Gids Commentaar
Veeery useful , thank you !
mouchtouris alexandre - Antwoord
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - Antwoord
Got the back panel off finally but my connector board won't come out.
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 273
Altijd: 49,249
