Ga door naar hoofdinhoud
Teddy Ruxpin Speaker Replacement
Wat je nodig hebt
  1. Teddy Ruxpin Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Teddy Ruxpin Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Speaker Replacement: stap 2, afbeelding 1 van 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Speaker Replacement, Arms: stap 4, afbeelding 1 van 3 Teddy Ruxpin Speaker Replacement, Arms: stap 4, afbeelding 2 van 3 Teddy Ruxpin Speaker Replacement, Arms: stap 4, afbeelding 3 van 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Speaker Replacement: stap 5, afbeelding 1 van 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Speaker Replacement: stap 6, afbeelding 1 van 3 Teddy Ruxpin Speaker Replacement: stap 6, afbeelding 2 van 3 Teddy Ruxpin Speaker Replacement: stap 6, afbeelding 3 van 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Speaker Replacement: stap 7, afbeelding 1 van 2 Teddy Ruxpin Speaker Replacement: stap 7, afbeelding 2 van 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Speaker Replacement: stap 8, afbeelding 1 van 2 Teddy Ruxpin Speaker Replacement: stap 8, afbeelding 2 van 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Speaker Replacement: stap 9, afbeelding 1 van 1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Speaker Replacement, Housing Cover: stap 10, afbeelding 1 van 3 Teddy Ruxpin Speaker Replacement, Housing Cover: stap 10, afbeelding 2 van 3 Teddy Ruxpin Speaker Replacement, Housing Cover: stap 10, afbeelding 3 van 3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Speaker Replacement, Speaker: stap 11, afbeelding 1 van 2 Teddy Ruxpin Speaker Replacement, Speaker: stap 11, afbeelding 2 van 2
    • Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
  12. Teddy Ruxpin Speaker Replacement: stap 12, afbeelding 1 van 1
    • Desolder the wire from the speaker and replace.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jayin Patel
406 Reputatie
4 handleidingen geschreven
Cal Poly, Team S18-G5, White Winter 2020 Lid van Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 693
