Ga door naar hoofdinhoud
Technique - Test the Battery
Wat je nodig hebt
  1. Technique - Test the Battery, Technique - Test the Battery: stap 1, afbeelding 1 van 3 Technique - Test the Battery, Technique - Test the Battery: stap 1, afbeelding 2 van 3 Technique - Test the Battery, Technique - Test the Battery: stap 1, afbeelding 3 van 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: stap 2, afbeelding 1 van 2 Technique - Test the Battery: stap 2, afbeelding 2 van 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: stap 3, afbeelding 1 van 2 Technique - Test the Battery: stap 3, afbeelding 2 van 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
    Have in mind that a 100% charged Li-ion battery can measure up to ~4.2 V
    Niky Nikolov - Antwoord
    Since I'm a total noob, and I'm sure I'm not the only person seeking this information. But could you mention which option to turn the dial to?
    Lisa Headrick - Antwoord
    Make sure it’s on Direct Current (DC) and probably 20V.
    joespeights1 - Antwoord
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Melinda Phan
438 Reputatie
9 handleidingen geschreven
Cal Poly, Team 9-64, Walters Spring 2011 Lid van Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Leden
18 handleidingen geschreven
2 opmerkingen
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Antwoord
yes,not tablet with battery removal difficult
paulbeames7 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 10,155
