Ga door naar hoofdinhoud
Technique - Test the Battery
Wat je nodig hebt
  1. Technique - Test the Battery, Technique - Test the Battery: stap 1, afbeelding 1 van 3 Technique - Test the Battery, Technique - Test the Battery: stap 1, afbeelding 2 van 3 Technique - Test the Battery, Technique - Test the Battery: stap 1, afbeelding 3 van 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: stap 2, afbeelding 1 van 2 Technique - Test the Battery: stap 2, afbeelding 2 van 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: stap 3, afbeelding 1 van 2 Technique - Test the Battery: stap 3, afbeelding 2 van 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Melinda Phan
438 Reputatie
9 handleidingen geschreven
Cal Poly, Team 9-64, Walters Spring 2011 Lid van Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Leden
18 handleidingen geschreven
2Gids Commentaar
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Antwoord
yes,not tablet with battery removal difficult
paulbeames7 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 10,467
