Ga door naar hoofdinhoud
Teac DC-D2831 Drive Belt replacement
Wat je nodig hebt
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: stap 1, afbeelding 1 van 2 Teac DC-D2831 Drive Belt replacement, Drive Belt: stap 1, afbeelding 2 van 2
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: stap 2, afbeelding 1 van 1
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: stap 3, afbeelding 1 van 3 Teac DC-D2831 Drive Belt replacement: stap 3, afbeelding 2 van 3 Teac DC-D2831 Drive Belt replacement: stap 3, afbeelding 3 van 3
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: stap 4, afbeelding 1 van 1
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
Conclusie
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
Charles Lockner
115 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-61, Propen Fall 2012 Lid van Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 3,584
