Inleiding
The Taylor 342D-27 is a machine that is often used by businesses to make slush-type drinks. A damaged valve will not allow the machine to have a proper seal and the contents will leak. This repair guide can help you replace the o-ring and get the machine back in top shape. The guide can be used when either of the two o-rings located around the valve become loose, damaged, or broken.
Wat je nodig hebt
Make sure the switch for the machine is straight down in the off position and that all contents have been emptied.
Één andere persoon heeft deze handleiding voltooid.
