Ga door naar hoofdinhoud
Tatung TAC-6G Light Element Replacement
Wat je nodig hebt
  1. Tatung TAC-6G Light Element Replacement, Light Element: stap 1, afbeelding 1 van 1
    • Start with the device standing upright.
  2. Tatung TAC-6G Light Element Replacement: stap 2, afbeelding 1 van 1
    • Remove the 11mm Phillips screw from below the power component panel.
  3. Tatung TAC-6G Light Element Replacement: stap 3, afbeelding 1 van 1
    • Pull the panel away from the rice cooker.
    • Remove the 9mm Phillips screw from behind the power component dashboard that is connected to the light plate.
  4. Tatung TAC-6G Light Element Replacement: stap 4, afbeelding 1 van 1
    • Pull the light plate from the power component panel.
  5. Tatung TAC-6G Light Element Replacement: stap 5, afbeelding 1 van 1
    • Flip the rice cooker device upside down.
  6. Tatung TAC-6G Light Element Replacement: stap 6, afbeelding 1 van 2 Tatung TAC-6G Light Element Replacement: stap 6, afbeelding 2 van 2
    • Remove the one 7mm Phillips screw from the side of the brass panel
    • Lift the brass plate off of the device and set it aside.
  7. Tatung TAC-6G Light Element Replacement: stap 7, afbeelding 1 van 1
    • Remove the 7mm Phillips screw holding the white and maroon colored wires that are connected to the heating element.
  8. Tatung TAC-6G Light Element Replacement: stap 8, afbeelding 1 van 1
    • Remove the 10mm Phillips screw that connects the white, blue and black wires to the white plastic piece in the corner of the device.
  9. Tatung TAC-6G Light Element Replacement: stap 9, afbeelding 1 van 1
    • Remove the 7mm Phillips screw that connects two white wires and one red wire to the heating "warm" switch.
  10. Tatung TAC-6G Light Element Replacement: stap 10, afbeelding 1 van 1
    • Using your hand, pull out the light plate with the maroon red and black wires.
  11. Tatung TAC-6G Light Element Replacement: stap 11, afbeelding 1 van 1
    • Replace the light plate dashboard.
Conclusie
Erin Charles
215 Reputatie
1 Handleiding geschreven
Één opmerking
Reverse the steps for reassembly.
Tom Anderson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 619
