Ga door naar hoofdinhoud
Tatung TAC-6G Heating Element Replacement
Wat je nodig hebt
  1. Tatung TAC-6G Heating Element Replacement, Heating Element: stap 1, afbeelding 1 van 1
    • Lift the lid and bowl from top of the device
    • Be sure device is not plugged in before beginning replacement of heating element
  2. Tatung TAC-6G Heating Element Replacement: stap 2, afbeelding 1 van 1
    • Turn the bowl upside down so that the three legs point upwards
  3. Tatung TAC-6G Heating Element Replacement: stap 3, afbeelding 1 van 2 Tatung TAC-6G Heating Element Replacement: stap 3, afbeelding 2 van 2
    • Remove the one 7 mm Phillips screw from the side of the brass panel.
  4. Tatung TAC-6G Heating Element Replacement: stap 4, afbeelding 1 van 2 Tatung TAC-6G Heating Element Replacement: stap 4, afbeelding 2 van 2
    • Remove the 6mm Phillips screw that holds the stainless plate.
  5. Tatung TAC-6G Heating Element Replacement: stap 5, afbeelding 1 van 3 Tatung TAC-6G Heating Element Replacement: stap 5, afbeelding 2 van 3 Tatung TAC-6G Heating Element Replacement: stap 5, afbeelding 3 van 3
    • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
  6. Tatung TAC-6G Heating Element Replacement: stap 6, afbeelding 1 van 1
    • Using your hands, remove the heating plate that is on top of heating element.
  7. Tatung TAC-6G Heating Element Replacement: stap 7, afbeelding 1 van 1
    • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
  8. Tatung TAC-6G Heating Element Replacement: stap 8, afbeelding 1 van 1
    • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
  9. Tatung TAC-6G Heating Element Replacement: stap 9, afbeelding 1 van 1
    • Using, your hands, take out the heating element and replace it with a new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
6 opmerkingen
where can I buy this heating element? Thanks.
dchang168 - Antwoord
Tze Moh Yeo - Antwoord
where to buy parts is the problem!!
William Co - Antwoord
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 41
Altijd: 4,175
