Ga door naar hoofdinhoud
Tara Pump Rod Replacement
Wat je nodig hebt
  1. Tara Pump Rod Replacement, Handle: stap 1, afbeelding 1 van 1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Pump Rod Replacement: stap 2, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 2, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Pump Rod Replacement: stap 3, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 3, afbeelding 2 van 2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Pump Rod Replacement: stap 4, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 4, afbeelding 2 van 2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Pump Rod Replacement: stap 5, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 5, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 5, afbeelding 3 van 3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Pump Rod Replacement: stap 6, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Pump Rod Replacement: stap 7, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 7, afbeelding 2 van 2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
  8. Tara Pump Rod Replacement, Pump Rod: stap 8, afbeelding 1 van 3 Tara Pump Rod Replacement, Pump Rod: stap 8, afbeelding 2 van 3 Tara Pump Rod Replacement, Pump Rod: stap 8, afbeelding 3 van 3
    • Screw the T-handle onto the top of the riser main.
  9. Tara Pump Rod Replacement: stap 9, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 9, afbeelding 2 van 2
    • Tighten the jam nut up against the base of the T-handle.
  10. Tara Pump Rod Replacement: stap 10, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 10, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 10, afbeelding 3 van 3
    • Use the T-handle to push the riser main back down into the well.
  11. Tara Pump Rod Replacement: stap 11, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 11, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 11, afbeelding 3 van 3
    • Once the riser main hits the bottom, turn the T-handle while pushing down.
    • This will hook the foot valve onto the traveling valve, allowing you to pull the two out of the well together.
    • You should feel some resistance if the foot valve is successfully attached.
  12. Tara Pump Rod Replacement: stap 12, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 12, afbeelding 2 van 2
    • Use the T-handle to pull the riser main straight up out of the well.
    • Take care to pull up slowly to ensure the foot valve does not get released from the hook at the end of the riser main.
  13. Tara Pump Rod Replacement: stap 13, afbeelding 1 van 2 Tara Pump Rod Replacement: stap 13, afbeelding 2 van 2
    • Continue pulling the riser main up from the well.
    • Pull the riser main until the base of the T-handle is at a comfortable height to work on.
  14. Tara Pump Rod Replacement: stap 14, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 14, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 14, afbeelding 3 van 3
    • Loosen the jam nut from the base of the T-handle.
    • Unscrew the T-handle from the top of the riser main.
    • Remove the T-handle, making sure to hold the remaining end of the riser main to prevent dropping it down the well.
  15. Tara Pump Rod Replacement: stap 15, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 15, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 15, afbeelding 3 van 3
    • Continue to pull the riser main out of the well.
  16. Tara Pump Rod Replacement: stap 16, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 16, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 16, afbeelding 3 van 3
    • Keep pulling until the first joint is exposed.
    • Lift the joint up to a comfortable working height.
  17. Tara Pump Rod Replacement: stap 17, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 17, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 17, afbeelding 3 van 3
    • Use two wrenches to loosen the top section of riser main from the lower section.
    • Unscrew the top section of the riser main.
    • Make sure someone is holding the remaining section of the riser main.
  18. Tara Pump Rod Replacement: stap 18, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 18, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 18, afbeelding 3 van 3
    • Remove the top section of the riser main.
  19. Tara Pump Rod Replacement: stap 19, afbeelding 1 van 1
    • Lay the first section of riser main in a sanitary place to prevent contamination.
    • Repeat the previous procedure to remove the remaining sections of the riser main from the well.
    • Lay each new piece in the order it was removed to aid in reassembly.
  20. Tara Pump Rod Replacement: stap 20, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 20, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 20, afbeelding 3 van 3
    • The last section of riser main will have the traveling valve screwed on to the end, and the foot valve hooked onto the traveling valve.
    • Be careful not to allow the foot valve to release from the hook by pulling slowly on the riser main.
  21. Tara Pump Rod Replacement: stap 21, afbeelding 1 van 3 Tara Pump Rod Replacement: stap 21, afbeelding 2 van 3 Tara Pump Rod Replacement: stap 21, afbeelding 3 van 3
    • Lift and twist the foot valve to unhook it from the traveling valve.
  22. Tara Pump Rod Replacement: stap 22, afbeelding 1 van 1
    • Once the riser main and valves have been removed from the well, place a rag over the top to prevent accidentally dropping anything down the well.
Conclusie
Sam Goldheart
465.771 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 385
