Ga door naar hoofdinhoud
Tara Handle Replacement
  1. Tara Handle Replacement, Handle: stap 1, afbeelding 1 van 1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Handle Replacement: stap 2, afbeelding 1 van 3 Tara Handle Replacement: stap 2, afbeelding 2 van 3 Tara Handle Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Handle Replacement: stap 3, afbeelding 1 van 2 Tara Handle Replacement: stap 3, afbeelding 2 van 2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Handle Replacement: stap 4, afbeelding 1 van 2 Tara Handle Replacement: stap 4, afbeelding 2 van 2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Handle Replacement: stap 5, afbeelding 1 van 3 Tara Handle Replacement: stap 5, afbeelding 2 van 3 Tara Handle Replacement: stap 5, afbeelding 3 van 3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Handle Replacement: stap 6, afbeelding 1 van 2 Tara Handle Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Handle Replacement: stap 7, afbeelding 1 van 2 Tara Handle Replacement: stap 7, afbeelding 2 van 2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
Conclusie
Sam Goldheart
465.762 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 204
