Ga door naar hoofdinhoud
Tapwave T2907US Zodiac 2 Motherboard Replacement
Wat je nodig hebt
  1. Tapwave T2907US Zodiac 2 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Motherboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 6, afbeelding 1 van 1
    Koop
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 8, afbeelding 1 van 2 Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 11, afbeelding 1 van 3 Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 11, afbeelding 2 van 3 Tapwave T2907US Zodiac 2 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
Conclusie
Michelle Cheung
13 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-33, Amido Winter 2012 Lid van Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,147
