Inleiding
If the control buttons on your device are faulty or have stopped working completely, this guide will aid you in replacing these buttons on the inside of the device.
Wat je nodig hebt
To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
This step is the primary step in reaching the components. It’s necessary to deform the metal housing at the four key points an 1/8” to release the four catches (two on top and two on the bottom). Once your spudgers, or shims (I used tweezers handles as shims), are in place pushing in the center of the back (on the plastic speaker grill) while holding the metal case lip I was able to slow push the internals out.
There is a key piece not shown in this step. Be sure to view how to remove the battery from TaoTronics TT-BA07 (formally listed as TaoTronics TT-SK06)( TaoTronics TT-BA07 Battery Replacement ). Once the battery cover is removed you can slide the internals out. Be very careful not to sever the antenna wire while removing the case.
Locate the four, 6mm screws on the board on top of the device. Unscrew them with the PH0 bit on the screwdriver so that the board may be removed.
3 opmerkingen
Great guide,to repair this bluetooth speaker. I have the same speaker from another brand.It called Aiser HSR 13.It is just cheaper, than the Tao Tronics.
Where can I get the control button?
Where can I get the button
I found removing the faceplate (grill) unnecessary for this repair.
Michael Johnstone - Antwoord
Hello I called the factory and they refused to even let me know which parts to buy since I successfully disassembled the unit and need to replace the 2x Micro DC connector in the pc board or where can I find a complete little board part to replace? Any support much appreciated
lee Jr. A - Antwoord
