Ga door naar hoofdinhoud
TaoTronics TT-SK06 Charging Port Replacement
Wat je nodig hebt
  1. TaoTronics TT-SK06 Charging Port Replacement, Front Grate: stap 1, afbeelding 1 van 2 TaoTronics TT-SK06 Charging Port Replacement, Front Grate: stap 1, afbeelding 2 van 2
    • To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    I found removing the faceplate (grill) unnecessary for this repair.
    Michael Johnstone - Antwoord
    Hello I called the factory and they refused to even let me know which parts to buy since I successfully disassembled the unit and need to replace the 2x Micro DC connector in the pc board or where can I find a complete little board part to replace? Any support much appreciated
    lee Jr. A - Antwoord
  2. TaoTronics TT-SK06 Charging Port Replacement: stap 2, afbeelding 1 van 3 TaoTronics TT-SK06 Charging Port Replacement: stap 2, afbeelding 2 van 3 TaoTronics TT-SK06 Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
    • Use caution when working with the metal spudger, as it can potentially damage your device.
    This step is the primary step in reaching the components. It’s necessary to deform the metal housing at the four key points an 1/8” to release the four catches (two on top and two on the bottom). Once your spudgers, or shims (I used tweezers handles as shims), are in place pushing in the center of the back (on the plastic speaker grill) while holding the metal case lip I was able to slow push the internals out.
    There is a key piece not shown in this step. Be sure to view how to remove the battery from TaoTronics TT-BA07 (formally listed as TaoTronics TT-SK06)( TaoTronics TT-BA07 Battery Replacement ). Once the battery cover is removed you can slide the internals out. Be very careful not to sever the antenna wire while removing the case.
  3. TaoTronics TT-SK06 Charging Port Replacement, Charging Port: stap 3, afbeelding 1 van 1
    • Locate the slit on the back of the device and the board will be located there. Remove board from slit by using tweezers.
  4. TaoTronics TT-SK06 Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Once board is removed, locate silver component on the board. This is the charging port. Remove the charging port. To put it back on the board you need to solder the component back onto the board.
    Where we can I find a replacement charging port?
    Juan Llantin - Antwoord
Conclusie
Niko Fabian
715 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-7, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-7, Landers Spring 2016
UMASSD-LANDERS-S16S5G7
3 Leden
Één opmerking
Ich bin bis Schritt 3 gekommen und wollte das Gerät komplett zerlegen nach dem ich die hinteren 8 Schrauben auch heraus gedreht hatte aber beide Gehäuseteile ließen sich nicht trennen. Was kann ich tun ?
Thorsten - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 2,554
