Ga door naar hoofdinhoud
TaoTronics TT-SK06 Charging Port Replacement
Wat je nodig hebt
  1. TaoTronics TT-SK06 Charging Port Replacement, Front Grate: stap 1, afbeelding 1 van 2 TaoTronics TT-SK06 Charging Port Replacement, Front Grate: stap 1, afbeelding 2 van 2
    • To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. TaoTronics TT-SK06 Charging Port Replacement: stap 2, afbeelding 1 van 3 TaoTronics TT-SK06 Charging Port Replacement: stap 2, afbeelding 2 van 3 TaoTronics TT-SK06 Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
    • Use caution when working with the metal spudger, as it can potentially damage your device.
  3. TaoTronics TT-SK06 Charging Port Replacement, Charging Port: stap 3, afbeelding 1 van 1
    • Locate the slit on the back of the device and the board will be located there. Remove board from slit by using tweezers.
  4. TaoTronics TT-SK06 Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Once board is removed, locate silver component on the board. This is the charging port. Remove the charging port. To put it back on the board you need to solder the component back onto the board.
Conclusie
Niko Fabian
715 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-7, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-7, Landers Spring 2016
UMASSD-LANDERS-S16S5G7
3 Leden
Één opmerking
Ich bin bis Schritt 3 gekommen und wollte das Gerät komplett zerlegen nach dem ich die hinteren 8 Schrauben auch heraus gedreht hatte aber beide Gehäuseteile ließen sich nicht trennen. Was kann ich tun ?
Thorsten - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 27
Altijd: 2,392
