Inleiding
In these instructions one will learn how to remove and replace the plastic screen for a kick drum.
In the demonstration below, the side being replaced is the one that has a microphone port, but these instructions are useful for either side of the kick drum. In this model, the bass drum is a Tama and has a diameter of 22 inches (the port hole cover is also 22 inches).
Wat je nodig hebt
Remove any attachments of the kick drum.
This includes symbols, toms, and kick pedal.
Place the new plastic cover port on top of the drum so it sits perfectly on it.
Depending which microphone port is being placed, adjust the cover so that words will be properly read when the drum is placed upright.
Press down on the edges of the drum cover so it is snuggled into the drum.
Finger tighten the bolts in a clockwise motion. Do this to all of the remaining bolts that are loose.
Evenly tighten the bolts with the same amount of pressure.
For an easier experience, tighten the bolts underneath the rim rather than above the rim. See the red box location in the pictures for clarification.
