Ga door naar hoofdinhoud
Tagital T9X Camera Replacement
Wat je nodig hebt
  1. Tagital T9X Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Camera Replacement: stap 2, afbeelding 1 van 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Camera Replacement, Camera: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, carefully remove the cloth covering from the ribbon connector for the camera.
  4. Tagital T9X Camera Replacement: stap 4, afbeelding 1 van 1
    • Use the tip of the spudger or your fingernail to flip up the small flap on the ZIF connector.
    • Carefully remove the ribbon cable from the connector.
  5. Tagital T9X Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the camera from its position at the top of the tablet.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 145
