Inleiding
Use this guide to replace the battery in the Tagital T9X.
Wat je nodig hebt
With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
Één andere persoon heeft deze handleiding voltooid.
