Ga door naar hoofdinhoud
Tagital T9X Back Cover Removal
Wat je nodig hebt
  1. Tagital T9X Back Cover Removal, Back Cover: stap 1, afbeelding 1 van 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Back Cover Removal: stap 2, afbeelding 1 van 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 201
