Ga door naar hoofdinhoud
Tagital T10 Camera Replacement
Wat je nodig hebt
  1. Tagital T10 Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4 mm Phillips head screws at the top of the device.
  2. Tagital T10 Camera Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
  3. Tagital T10 Camera Replacement: stap 3, afbeelding 1 van 1
    • Pull the black tape away so that the rear-facing camera is no longer attached to the device.
  4. Tagital T10 Camera Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Pull off the plastic camera cover with the tweezers so that the front-facing camera can move freely.
  5. Tagital T10 Camera Replacement: stap 5, afbeelding 1 van 1
    • Locate the small ZIF connector that connects to the cameras.
    • Use the plastic prying tool to pull up the black tab, so that the filament is released. Carefully pull the filament out so it is moving freely.
    • The camera can now be lifted from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Destin Dawsy
328 Reputatie
2 handleidingen geschreven
USF Tampa, Team 14-5, Eyestone Fall 2016 Lid van USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 280
