Ga door naar hoofdinhoud
Table Lamp Bulb and Wiring Replacement
Wat je nodig hebt
  1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: stap 1, afbeelding 1 van 1
    • Switch off the lamp to ensure no electricity is flowing.
    • Unplug the lamp from the power outlet to prevent the risk of electric shock.
    • Wait a few minutes to allow any remaining electrical charge to dissipate.
  2. Table Lamp Bulb and Wiring Replacement: stap 2, afbeelding 1 van 1
    • Locate the screw at the base of the lamp that secures the light fixture to the structure.
    • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
    • Keep the screw in a secure place to avoid losing it during reassembly.
  3. Table Lamp Bulb and Wiring Replacement: stap 3, afbeelding 1 van 1
    • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
    • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
  4. Table Lamp Bulb and Wiring Replacement: stap 4, afbeelding 1 van 3 Table Lamp Bulb and Wiring Replacement: stap 4, afbeelding 2 van 3 Table Lamp Bulb and Wiring Replacement: stap 4, afbeelding 3 van 3
    • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
    • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
  5. Table Lamp Bulb and Wiring Replacement: stap 5, afbeelding 1 van 3 Table Lamp Bulb and Wiring Replacement: stap 5, afbeelding 2 van 3 Table Lamp Bulb and Wiring Replacement: stap 5, afbeelding 3 van 3
    • Take off the white cover from bottom to top.
  6. Table Lamp Bulb and Wiring Replacement: stap 6, afbeelding 1 van 2 Table Lamp Bulb and Wiring Replacement: stap 6, afbeelding 2 van 2
    • Cut both of the old wires with wire cutters.
  7. Table Lamp Bulb and Wiring Replacement: stap 7, afbeelding 1 van 2 Table Lamp Bulb and Wiring Replacement: stap 7, afbeelding 2 van 2
    • Take out the new wire and make sure lamp wires correlate to its terminal.
    • Neutral is marked blue, hot is marked red.
  8. Table Lamp Bulb and Wiring Replacement: stap 8, afbeelding 1 van 1
    • Thread the wire through the small hole under the lamp.
  9. Table Lamp Bulb and Wiring Replacement: stap 9, afbeelding 1 van 2 Table Lamp Bulb and Wiring Replacement: stap 9, afbeelding 2 van 2
    • Secure the wires to the screws using a Phillips screwdriver.
    • Tighten the screws so that the wires are secured under the screws.
  10. Table Lamp Bulb and Wiring Replacement: stap 10, afbeelding 1 van 1
    • Use a Phillips screwdriver to screw the wire between its correlating screw.
    • Blue is neutral, red is hot.
  11. Table Lamp Bulb and Wiring Replacement: stap 11, afbeelding 1 van 1
    • Plug the lamp in, and the bulb will light up.
Eindstreep
Jeffrey Cong
193 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-3, Andersen Winter 2025 Lid van UC Davis, Team 3-3, Andersen Winter 2025
UCD-ANDERSEN-W25S3G3
3 Leden
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 28
Altijd: 316
