Ga door naar hoofdinhoud
TOSHIBA Satellite E45W-C4200X TrackPad Replacement
Wat je nodig hebt
  1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: stap 1, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 2, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 2, afbeelding 2 van 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 3, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 4, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 5, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 5, afbeelding 2 van 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the laptop.
  7. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, TrackPad: stap 7, afbeelding 1 van 1
    • Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
  8. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 8, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 8, afbeelding 2 van 2
    • Use the spudger to peel up the keyboard cover.
    • Use caution when removing keyboard cover.
  9. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 9, afbeelding 1 van 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 9, afbeelding 2 van 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: stap 9, afbeelding 3 van 3
    • Use the heat gun to apply heat to the track pad and use the metal spudger to remove the track pad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 305
