Ga door naar hoofdinhoud
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
Wat je nodig hebt
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 2 van 2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 2, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 2, afbeelding 2 van 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 3, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 4, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 5, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 6, afbeelding 1 van 3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 6, afbeelding 2 van 3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: stap 6, afbeelding 3 van 3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
Conclusie
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 345
