Inleiding
This guide will walk you through the necessary steps for replacing the battery pack in your Toshiba Satelite E45W-C4200X.
The battery is a vital piece of hardware that allows the laptop to run when not plugged in. A defective battery can prevent the laptop from turning and can result in longer charging times or short battery life.
Before using this guide, make sure to review the troubleshooting page oftentimes, the battery can be fixed without replacing it.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Wat je nodig hebt
Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
