Ga door naar hoofdinhoud
TOSHIBA Satellite E45W-C4200X Battery Replacement
Wat je nodig hebt
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: stap 1, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 2, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 2, afbeelding 2 van 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 3, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 4, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 5, afbeelding 1 van 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 5, afbeelding 2 van 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 2,031
