Inleiding
Replace the cracked or damaged screen of TI-Nspire Calculator to enable the display for more efficient use of the device.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Place the calculator screen facing down with the back plate facing up.
Now, turn the calculator over so the back plate faces up.
Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner.
Repeat the prying step on the right side, moving along the perimeter of the calculator.
Repeat the prying step on the top right corner.
Remove the four batteries to help prevent electrical shorts in later steps.
Één andere persoon heeft deze handleiding voltooid.
2 Opmerkingen
Great guide! Just wondering where you found the replacement LCD? I've searched and searched the guide and the Internet and can't seem to locate them. Any help is greatly appreciated! Thanks!
