Ga door naar hoofdinhoud
TI-84 Plus Silver Edition Backup Battery Replacement
Wat je nodig hebt
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: stap 1, afbeelding 1 van 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: stap 1, afbeelding 2 van 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: stap 1, afbeelding 3 van 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: stap 2, afbeelding 1 van 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: stap 3, afbeelding 1 van 1
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: stap 4, afbeelding 1 van 1
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: stap 5, afbeelding 1 van 2 TI-84 Plus Silver Edition Backup Battery Replacement: stap 5, afbeelding 2 van 2
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Agustin
1.028 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-34, Amido Fall 2013 Lid van Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Leden
6 handleidingen geschreven
9 opmerkingen
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Antwoord
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Antwoord
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Antwoord
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 144
Altijd: 66,290
