Ga door naar hoofdinhoud
TDK Life on Record Trek Max A34 Battery Replacement
Wat je nodig hebt
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: stap 1, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: stap 2, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Battery  Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: stap 3, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Battery  Replacement: stap 3, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Battery  Replacement: stap 3, afbeelding 3 van 3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: stap 4, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Battery  Replacement: stap 4, afbeelding 2 van 2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: stap 5, afbeelding 1 van 1
    • The battery is now separated from the device and may be replaced with a new battery.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Kayla
315 Reputatie
1 Handleiding geschreven
Texas Tech, Team 19-3, Rauch Fall 2015 Lid van Texas Tech, Team 19-3, Rauch Fall 2015
TTU-RAUCH-F15S19G3
4 Leden
1 handleiding geschreven
2 opmerkingen
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - Antwoord
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 11,343
