Ga door naar hoofdinhoud
TDK Life on Record A33 Speaker Replacement
Wat je nodig hebt
  1. TDK Life on Record A33 Speaker Replacement, Speaker Guard: stap 1, afbeelding 1 van 1
    • Push the nylon or metal spudger in the corner of the speaker guard.
  2. TDK Life on Record A33 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Slowly lift the speaker up enough so that you can slide around the speaker guard.
  3. TDK Life on Record A33 Speaker Replacement: stap 3, afbeelding 1 van 2 TDK Life on Record A33 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Slide the nylon or metal spudger all around the speaker guard.
  4. TDK Life on Record A33 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
  5. TDK Life on Record A33 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 TDK Life on Record A33 Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Remove all (4) 3mm screws in the middle speaker using a Phillip's head screwdriver.
    • You can also remove the speakers on the left and right.
  6. TDK Life on Record A33 Speaker Replacement: stap 6, afbeelding 1 van 2 TDK Life on Record A33 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Do not rip the wires inside the speaker when trying to open the middle speaker on the device.
    • Create an opening in the speaker by holding the device up and carefully grabbing the side of the speaker that pops out.
  7. TDK Life on Record A33 Speaker Replacement: stap 7, afbeelding 1 van 2 TDK Life on Record A33 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Wear safety goggles and have something to absorb the smoke from the soldering iron just in case.
    • Do not burn the wires of the speaker.
    • Remove the solder that connects the wires to the speaker. You should be able to now remove the speaker and replace it.
Conclusie
Matthew Phou
448 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-2, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Leden
5 handleidingen geschreven
3 opmerkingen
Where can I buy the woofer?
stevealvarado54 - Antwoord
Really, stevealvarado! What's The point of taking this all apart if you don't have a replacement to put in?
Van Moon - Antwoord
If l need a second opinion about which speaker is blown, who or where can can l get it diagnosed?
Tony - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 4,420
