Ga door naar hoofdinhoud
TDK Life on Record A33 AC Adapter Prongs Replacement
Wat je nodig hebt
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: stap 1, afbeelding 1 van 1
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: stap 2, afbeelding 1 van 2 TDK Life on Record A33 AC Adapter Prongs Replacement: stap 2, afbeelding 2 van 2
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: stap 3, afbeelding 1 van 1
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Festa
808 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-2, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 2,578
